Hello.
I'd like to know if there should be any performance difference between these two DDR4 types of memories and if I'd notice, specifically the DDR4 3200 MHz PC4-25600 32GB 2x16GB CL16 for both.
I ordered the RGB Pro ones but I checked a comparison in that site and it shows that the LPX have a 3% higher effective speed difference from the RGB Pro's
Here's the direct link for the comparison.
https://ram.userbenchmark.com/Compa...ance-LPX-DDR4-3200-C16-2x16GB/m587593vsm97244
I've also read that the LPX are better for overclocking due to their design and the RGB Pro, well, they have RGB.
I'm not planning on overclocking but I'd like to get the best performance.
Thank you for your help.
Pak
Pak
