Do I have a Prescott? I got Fry's special a few months ago which was a P4 w/motherboard. The Pentium is 533 FSB, 512 kb l2 cache, socket 478, running out of the box at 2.53 ghz. The bundled motherboard is the ECS l4vxa2. It works fine and I have no complaints - doenn't get hot. Today Fry's has a sale for the athon 64 3200+ with mboard (they don't say what kind - it has audio onboard and SATA) for $189. That sure seems like a good price - my question is this: will it improve on my ability to rotate and manipulte 3d objects, using the free 3dbrowser, and using both ac3d and max6 to generate new 3d objects? The reason I ask is that I also have an older 1 ghz P3 to which I compared my new 2.53 P4 with, and I can definitely see an improvement as the 3d objects I load get more triangles. The old 1 ghz will not keep up when there are several thousand triangles (it jumps as I move the mouse in rotate or pan mode). But the 2.53 ghz P$ keeps up until I load 3d objects that are even more thousands of triangles - then it starts to jump somewhat. Will the 64 3200+ perform noticebly better? Or is it more the video card than the cpu? Both video cards are normal 128 mg type standard cards (sub $100 price range). I see that this ability to keep up (both in smooth and wireframe mode) when rotating, panning, and zooming a 3d object is of key value when one wants to demonstrate a complicated 3d object - so, a better perfoming setup is worth looking into. I am running both win98se and win2000 (for max6). Thanks, littleberry
