marioantunovic13 Prominent Jul 7, 2018 11 1 515 Jul 11, 2019 #1 I'm in search of a 775 socket budget CPU Air cooler for my Intel Xeon x5460 which I'm planning to overclock(the only real criteria is the heatsink width which should be 120mm Reactions: SunnyShahi
Solution Eximo Jul 11, 2019 Width can mean several things in this context. Hundreds to choose from, what do you mean by budget? 120W rated CPU, so it can't be too 'budget'. https://pcpartpicker.com/product/hJFPxr/deepcool-cpu-cooler-gammaxx400 Scythe Kotetsu 79 CFM CPU Cooler pcpartpicker.com Old fashioned Hyper Evo 212 from Cooler Master would work, just have to make sure to get the 775 compatible one. If you needed something lower profile, you could do worse: https://pcpartpicker.com/product/8mTmP6/thermaltake-cpu-cooler-clp0534 And this is a decently rated cooler with a 92mm fan: https://pcpartpicker.com/product/cwPzK8/be-quiet-cpu-cooler-bk009
Eximo Titan Ambassador May 27, 2010 28,408 5,782 144,340 Jul 11, 2019 Solution #2 Width can mean several things in this context. Hundreds to choose from, what do you mean by budget? 120W rated CPU, so it can't be too 'budget'. https://pcpartpicker.com/product/hJFPxr/deepcool-cpu-cooler-gammaxx400 Scythe Kotetsu 79 CFM CPU Cooler pcpartpicker.com Old fashioned Hyper Evo 212 from Cooler Master would work, just have to make sure to get the 775 compatible one. If you needed something lower profile, you could do worse: https://pcpartpicker.com/product/8mTmP6/thermaltake-cpu-cooler-clp0534 And this is a decently rated cooler with a 92mm fan: https://pcpartpicker.com/product/cwPzK8/be-quiet-cpu-cooler-bk009 Upvote 0 Downvote Solution
