First of all here goes my rig :
Motherboard : Asus ROG Strix B250G Gaming
CPU ; i5 6400
Ram : 2x 8gb DDR4
GPU : Nvidia GeForce GTX 1060 3gb
CPU Fan : NOX Hummer H212
(If you need any more info to answer just ask please)
I've had this rig for about 6-8 months and it never had any kind of hardware problem but recently for some reason when I start my pc on, the CPU fan spins for half a second and then stops, then there comes the beeping (1 long and 4 short if I'm not mistaken) and then it appears the "American Megatrend" thing with a "CPU fan error" message close to the end and then a "Press F1 to enter BIOS" or something like that at the end.
So after a few resets and a "plug and unplug thingy" to the cpu fan cable, it gets back to work but it seems to be totally random: I've already had to reset my pc only 5 times to make it work and already happened to reset 20 times and it still didnt work. Also if I turn it off later then it gets the same problem. Even though it already happened once or twice that I turn it off and turn it back on and it worked
I've been searching here for quite a while but didn't found any problem like mine that "gets solved momentaneous after a few resets"
Already tried cleaning the connecting zone and the cable, unplugged everything from my pc (keyboard, mouse, headset, 2nd monitor) letting only my 1st monitor and the energy cable, Plug and Unplug the cable (as I said before)
CPU ; i5 6400
Ram : 2x 8gb DDR4
