[SOLVED] CPU making Electronic sound
Aug 23, 2019
Hi, I am Puneet,
There is some electronic kind of sound comes from cpu.
Can anyone help me out what this sound can be.
My PC config is:
Processor:
Intel i9-9900k upto 5.0Ghz
Motherboard: Gigabyte – Z390 Aorus Ultra
Cooler: NZXT - KRAKEN X72
Graphic Card: NVIDIA –Gigabyte RTX 2080ti Gaming OC 11GB DDR6
RAM: g.skill trident z rgb 8gb ddr4 3000
Power Supply: Corsair – CX750
SSD: Samsung 970EVO 500GB M.2 NVME
HDD: 2TB Seagate
Case: Lian Li Lacool one
it is more likely to be one of the fans that is making the noise.
Try disconnecting all of your PC case fans, removing your GFX card and connecting your monitor to your integrated graphics on the back of your PC.
Your CPU has integrated graphics.
If the noise still persists then it sounds like the CPU fan.
You can manually increase its speed temporarily in your BIOS to see if the noise changes/gets louder/stops.
Andy
Andy
Andy
Thanks, will try this and get back to you...
