I'm looking to upgrade the processor on an old FIC AD11 motherboard (Socket A, AMD-761, DDR) with the fastest CPU it will support. I built this system (and three others over the years) so I'm not completely clueless, but I still have a couple of questions.
FIC's website has the board approved up to the Athlon XP 2000+ (Palomino / Model 6). AMD's webpage for the AD11 has the board approved up to the Athlon XP 1800+ (Palomino / Model 6). The .pdf file off of FIC's website with the approved CPUs was created on 01/11/2002, and I don't know when AMD's page for the AD11 was last updated.
I have several questions:
Assuming the CPU support tables are both still correct (which seems dubious), can I trust FIC's recommendation even though it exceeds what is on AMD's supported list?
If 1800+ or 2000+ is the limit, is there a reason I wouldn't be able to use an +1800 or +2000 from a later model Athlon XP (Thoroughbred / Model 8 or Thorton / Model 10)?
Is there a possibility I can go faster than a 2000+? I have never overclocked and don't really want to start now, but I'm not sure I would even have to. The clock speed is 133 MHz. The multiplier still confuses me. There are jumper settings for 5x to 12.5x, but in the motherboard manual the highest setting is listed as >=12.5x. The CPU support chart from FIC also shows support for an AMD Athlon-1.4G running at 100x14. Could I potentially have a processor running at 1867 MHz (133x14)?
These are old components and FIC's customer service is pretty much non-existent. Any tips you guys could provide would be wonderful. I know this is a lot, and that surely some of these questions are dumb. Thanks to any of you who read through it all. Please let me know if there's anything else you need to know. Thanks in advance.
-Jim
-Jim
