I have Intel core2quad q6600 2.4 CPU which i brought 3 years ago. It ran fine 37C-40C while ideal and 58C-63C while play games or CPU at full load.
But now CPU temperature rise over 75C while gaming. And also I found a software called prime95 and ran it.
Then after 7 or 8 minutes is rises over 80C so i stopped prime95.(I used core temp to measure, and speed fan gives 10C different to that)
After that remove CPU fan and clean it. But nothing is changed. I am sure i fix CPU correctly and reapplied thermal compound also. So what's wrong please help
And also I have little worry about my CPU fan, It is same old which is came with stock. And I set CPU fan speed to full in bios, But I get 2500rpm-2900rpm which is shown in Speed Fan software.Is this normal or I have to change CPU fan?
Please help...
Please help...
