[SOLVED] Cpu running 50 degrees at idle
Aug 25, 2020
I have a Intel core i5 7500 with an acrctic cool alpine 11 pro revision 2 and in idle my CPU is running at 50 degrees and at load 70 to 80 degrees, I have one cooling fan bringing in fresh air from the front and 2 exhaust fans. What can I do to make it run cooler because I know it shouldn't be like that.
The alpine 11 isn't a very good cooler.
That said it should do better than that.
Make sure the plastic fixing screws are all locked down, they have a habit of loosening themselves.
A better cooler would honestly be advised though.
