G
Guest
Guest
Archived from groups: alt.comp.hardware.pc-homebuilt,microsoft.public.windowsxp.hardware (More info?)
First of all, thanks to everyone (on a previous thread) who suggested
a few changes on my PC's fans to improve the CPU temperature. I ended
up redirecting the fans on the side panel from "exhaust" to
"intake"... and I moved the extra exhaust fan at the back of my PC
further down, away from the power supply. The idle CPU temperature
went from 45 degrees all the way down to 37! And the peak temperature
under heavy load went from 64 degrees to 58 degrees. I was amazed at
the drastic temperature drop from simply moving the fans around.
But a strange thing happened: My system temperature went from 32, all
the way up to 42. I had thought that a better air circulation, which
lowered CPU temperature, would also lower the system temperature.
Instead, system temperature went up by a full 10 degrees.
I don't get it at all. I find it hard to fathom that the system
temperature would be five degrees higher than the CPU temperature. I
would expect it to be the other way around. In fact, I'm worried now
that the motherboard's temperature sensors are either broken, or
unreliable. The system temperature reading remains fairly constant
(+/- 1 degree) even when the Radeon 9800 Pro card and the CPU are
working full speed. Is 42 degrees too hot for a system temperature
during idle time?
Anyway, am I better off with the new setting (CPU 37-58 degrees,
system 42 degrees) or the old setting (CPU 45-64 degrees, system 32
degrees)?
during idle time?
degrees)?
