cpu upgrade help
shadows1234
1,343
Hi all im looking to upgrade my cpu
To something that is quad core
I will use this for gaming on medium setting also i got fm2/fm2+ motherboard and budget is $150 so what should i get
voltoid27
609
It would help to know what you already have so we have a good basis for comparison.
The A10-6800K is a great deal right now: 4.1 GHz of quad-core APU goodness for $125 at http://www.amazon.com/dp/B00CPLGGXM/?tag=pcpapi-20. Just make sure your CPU cooler can handle 100W of heat to dissipate.
G
Guest
Guest
I'd have to put in my vote for the A8 7600 over the a10 6800k for the added GPU horsepower. It is slightly cheaper than the 6800k, but cannot overclock and loses a bit on raw CPU performance to the 6800 due to lower clock rates. But it also uses less power at 65 Watts (will run cooler) and is able to be configured to run at 45 Watts (will run a lot cooler) with only a slight loss in performance. If you don't mind spending a bit more, the a10 7800 is a great choice for an entry level gaming system with an even stronger GPU in it and higher clocks than the a8 7600, though it is about $160. The stock heat sinks are able to keep them cool enough for everyday non overclocked use, but are quite loud compared to aftermarket ones. If you want an aftermarket one, the CM 212 EVO is excellent, but it is quite tall so make sure you measure the inside of your case to be sure it will clear. Cooler Master should have specs on their website that wil give you the dimensions of the cooler. If not, there are some good downdraft style coolers that will work well too. Here's one I've used a few times with great results. http://
