Question Crossfire Help using R9 370
The No Face Guy
Commendable
Feb 15, 2019
26
Hi. I have a question for all the viewers of this thread. Does AMD Radeon R9 370 support crossfire? If yes, is it worth it? If no, can the GTX 760 do SLI?
I am planning to do the crossfire on Gigabyte GA-B85-HD3 in case you need it.
And one last thing, I created a poll for you to say which one is better.
Alright. Thanks for your help. Which one of the following do you think is better? I created a poll above. Just say which one is best among them.
the GTX 960 is the best one there performance wise. I would recommend you get the GTX 960 4GB instead of the 2GB variant. Do you have a budget for the GPU? If yes let me know how much you're ready to spend. I'm pretty sure I can recommend something better than the 3 you wrote up there.
Err.. you're gonna laugh by seeing this. AMD Radeon R7 240. YES. I know just see what the plan is. I am upgrading my PC totally.
Let me show you what I am doing.
OLD SPECS:
CPU: Amd Phenom II x4 B55 @3.2Ghz
RAM: 10GB 1600MHz
GPU: You know about this...
Mobo: BIOSTAR T-Series TA880GB+
NEW SPECS:
CPU: Intel Core i7 4790 @ 3.6Ghz
RAM: That same good ol' DDR3 10GB
GPU: As you told, a GTX 960 by Gigabyte.
OLD SPECS:
RAM: 10GB 1600MHz
NEW SPECS:
The i7 4790 is better than that old AMD Phenom II x4 955 BUT it's not the same socket as the i7 which is intel. You will need a new motherboard and with a new motherboard you will have to look if that RAM is supported in that new motherboard at the board official website memory support list.
