Question ddr4 gskill tridentz 3000mhz running at 2800
Apr 23, 2019
4
I cant seem to get the memory to 3000mhz. its just annoying since it says it will run that speed but I cant seem to get it there. Ram is currently at 2800 with xmp enabled the motherboard is gigabyte Aorus pro wifi, i5-9600K, gpu is a 2070 xc theres so much on the web about it but none of it really helped. it was at 2600 but I managed to reach 2800 but that seems about as far as I can get it to go. any suggestions or ideas?
Apr 23, 2019
4
yep xmp profile 1 is all there is and its set at 3000 but even that alone only took it to 2600. I had to mess around to get it to 2800.
clutchc
Herald
Odd. I also have an i5-9600K, but on an MSI Z390A-Pro board using G.Skill RAM (Aegis 16GB (2x8GB)), and the XMP 3000MHz setting worked fine. And my RAM is cheaper than yours. My XMP also only has one profile. Have you got the latest BIOS/UEFI for the board?
Feb 23, 2019
69
8
35
Anyway to manually overclock it to the desired speed? I know there is but have you actually tried it rather than the XMP profile?
Apr 23, 2019
4
it reads at 3000mhz with only one module. one module was very selective while one worked at 3000mhz in all dimms the other module had to be in certain dimms to read 3000mhz is that normal? I will try to load bios defaults and try again.
Similar threads
