I'm having AMD phenom ii x6 1090t on Asus M4A89GTD PRO/USB3 motherboard.
Core processor speed is 3.2 ghz, however I've enabled turbo unlocker for better fps in games.
Now, idle temp is around 45/47 which I think is quite on higher side.
I've changed thermal paste once in last 6 years. Also, I guess stock cooler heatsink doesn't look in a good shape.. Thinking of replacing the cooler to achieve better clock speeds.
I've shortlisted 2 AIO & 2 Air coolers depending on my budget and their availability in my region..
Deepcool Gammaxx L120t
Corsair H45
Cooler Master Hyper H410R
Deepcool Gammaxx 400v2 / GTEv2
I'm mostly using my pc for playing csgo for couple of hours per day.
Q1. Do I really need to change the cooler or 47c idle temp is fine?
Q2. This is the first time I'll be changing cooler, shall I go with liquid or Air?
Q3. Which cooler shall I go with from above 4? You can suggest any other but it shouldn't cost more than any of these 4..also I hope availability won't be a problem.
Corsair H45
