Hello
About a year ago I bought a used laptop without battery. Product model is Dell latitude E5250. And due to the constant use of the charger as a power supply, the laptop BIOS had a serious problem. After getting it repaired, I bought the battery (P/N:RYXXH), but there was no cable to connect the battery to the motherboard in the package & I couldn't find the cable at any local store. it's middle east 🙁
Does anyone know the pinout of this cable? Or the battery and motherboard connector? So I can DIY the wiring from battery to the motherboard. I could not find anything useful on the web about this pinouts!
Similar models are: Latitude E5270, E5450, E5470, E5550, E5570
Any help is highly appreciated. Even the name/type of connectors that are used in this cable.
https://ibb.co/MGKQPs3
