Kevin_122
28
Hi everybody!
I have a weird problem at the moment, i had a battery gone bad and it wouldn't charge anymore. I decided to change the battery with a random aftermarket one at first and it seems it didn't work as well. So the new battery was sent back under warranty and i got a new one that has Dell writings on it so it seems to be the original.
But as the aftermarket one it still won't charge and says plugged in.
Things i have tried:
Bios update
CMOS reset
Uninstalling battery controllers from device manager
Tried 2 batteries(aftermarket and dell)
Tried 2 different ac adapters(65w and 90w)
Downloaded and installed all the updates through dell support assitant and windows updates
I'm not sure what to try anymore.
Thanks for all the suggestions
Latest posts
