G
Guest
Guest
Archived from groups: alt.sys.pc-clone.dell (More info?)
The PE1750 uses the same 1G module as a few Dell systems as given by
the following:
http://accessories.us.dell.com/sna/productlisting.aspx?c=us&l=en&cs=04&cat=snp&s=bsd&category_id=5358&sku=&mnfsku=&SearchType=&Page=productlisting.aspx&Pageb4Search=&spagenum=1&orderby=mfg_part_num&SubmitSearch=&iCompatid=&brandid=&mnf=&InStock=&k=MT36VDDT12872G265B1&prst=&prEnd=&x=0&y=0
The manufacturer part number is MT36VDDT12872G265B1 which is a Micron
MT36VDDT12872. Reference the following:
http://download.micron.com/pdf/datasheets/modules/ddr/DD36C128_256_512x72G_C.pdf
The 2G PE650's I have use the Micron part and the 2G PE2650's I have
use a Netlist NL9127RD65042-D21J,
http://www.netlistinc.com/qualified.html. I will upgrading the PE650's
to 3G and the PE2650's to 4G using the same parts. The PE1750 and
PE2650 do two-way interleave so they have to upgraded in pairs.
the following:
