Hi, I am having trouble with booting my desktop. So let me get straight to the problem, after I press the power button the POST beep will sound off and the monitor will light up (it will not display anything, the monitor will just light up, but its still black) And it will stay like that until I wait for about 10mins then I plug it off then plug it on again and when0 I press the power button this time it will work normally. It always happen every time I open my desktop. What could be the cause of this problem, I suspect the RAM is the issue, if not the whole chassis is grounded (since I got grounded by touching one of the corners of my HDD, but that was long time ago). Any suggestions to solve this guys? I do not want to do this tedious process every time I open my desktop.
SPECS:
Intel i5 3470 @ 3.20GHz
4GB Kingston Ram
Asus H61M- C Motherboard
WD 1TB Blue HDD
Corsair VS550 550watt
No GPU (only the integrated one)
Note:
There is a post beep on the initial boot up (maybe its a different beep code? I dont know it sounds very very alike with normal post beep)
After the whole desktop boots normally, there is like a timer to which you can boot the desktop normally (like maybe 2hrs?) and after that you need to repeat the process of power on, wait 10mins, plug out plug in, power on again.
And desktop is also running dual-boot if that is any help.
SPECS:
4GB Kingston Ram
WD 1TB Blue HDD
Note:
