difference between mini usb and usb
poly4life
158
Just so there is no confusion, despite what I wrote in the Subject header, I am well aware of what mini usb A/B and usb A/B/AB look like and am confident that there are no bandwidth or length differences between the two, either. What I do want to know, though, is if there are no differences in performance or ease of implementation, why does a manufacture use mini-B as opposed to reglular B? I mean, why not embedd mini USB A into a mobo instead of regular old USB A, for instance? I believe the USB specification calls for certain procedures, but I'm not sure how these procedures relate to peformance or design implementation.
Thank you very much.
it's just a cable diversion, like firewire 4-pin and 6-pin
some devices are so small, that regular usb would be overkill
Abit IS7 - Prescott 3GHZ@3.6ghz - i865PE - 1024mb dual ddr400 - Geforce 2 MX400 64MB - 600W dualfan(front/rear) PowerTek Psu - maxtor 4K080H4 & 6Y120P0 - samsung sm-352b
