Hi, hope you're doing well!
Been building computers for over 13 years now, so you can bet I'm asking after trying to figure it out as best as I could.
I got a simple question but its rather particular.
I've been doing a lot of builds lately and there have been so many different kinds of connectors I've seen. I'm familiar with the 12v 4 pin, 5v 3 pin, and 5v VGD 3 pin.
Now I saw some hubs / fans that combine power and led into 6 pin connectors. And then today I just received a case that has those in 5 pin connectors!
What in the world is going on?! Are companies just making whatever proprietary connector they want? Is the 3 pin on the right VGD?
Also last week, I bought an LED strip that has 3 connectors, the 5v 3 pin (skipping one in the middle), VGD 3 pin, and a new 5v 4 pin. surprisingly my hub has it too.
In searching for an image for this post, I saw this which labels it as 'for hub' but what is this connector? Is it particularly for light strips for hubs? any more info? I would love a comprehensive list on all of them.
The amount of RGB connectors is getting out of hand. When I saw the 6 pin, I also saw I believe Corsair or a bigger name brand doing it, so I thought okay, they've consolidated RGB and PWM / Power, into one, that's fine and dandy, but after seeing the 5 pin today, that's thrown out the window and I'm quite confused.
Also, that case I bought with the 6 pin was probably one of the most well done hubs I've seen, except for the fact that it was 6 pin, it was a Musetek case, with an IR remote and I guess a microphone because it could be controlled by music. Couldn't plug the AIO cooler into it however (because it was 6 pin only)
Then I've also used a Montech case w hub, which was pretty solid, that supported the usual PWM connectors and 5v 3 pin on its hub and then the single button on the case controlled everything, AIO cooler, strips, fans, you name it.
Would love some kind of list or link to a list. Or if you wanna vent too, join in lol
