well I want to set a CoolerMaster Vertical Graphics Card Holder Kit on to my pc and the thing is can it go on a corsair crystal 570x SE with a aorus 2080 super like does the vertical holder hold it in the case
Well my whole pc isNot without modification as the 570x has metal slats between the pci-e slot covers. So you'd have to cut/remove these or they would block the back of the card.
The cablemod vertical mount would not require any modification, but does cost a little more and will make accessing the ports harder.
View: https://www.youtube.com/watch?v=hYMb5hdBRkQ
Also what cpu cooler are you using? Where the case has only seven pci-e slots and the Aorus is a tall card vertically a big air cooler would get in the way. I ran into this problem with a Noctis 450(i cut out the pci-e slats to use the coolermaster vertical mount), an Aorus 1080 and a Cryorig R1 cpu cooler.
Well my whole pc is
Corsair H100i Platinum waterkoeler
Corsair Vengeance RGB RAM 8x4
msi MPG z390 gaming plus
Aorus 2080 super
The thing is with the cablemod is that you need to have different cables to have it in place that will cost more because I need to buy sepprated cables for DP or HDMIwith 90 grade something something what would you do
Okay yeah I understand what you mean I will do it save and not cut in to my slots I will search for more info just to make sureIt's up to you, when I ran into that situation I used a Dremel with a cutting disc to mod the case. While not a hard mod to do it will take time do do properly as you'd want to completely disassemble the system and case then clean it thoroughly afterwards to reduce the risk of metal shavings getting into a bad place(s) and damaging components.
