Does my Printer "Brother mfc-7860dw" NOT have a USB 2.0 female port?
According to that manual, yes.
"USB cable
• It is recommended to use a USB 2.0 cable (Type A/B) that is no longer than 2 metres.
• DO NOT connect the interface cable at this time. Connecting the interface cable is done during the MFL-Pro
installation process"
Have you looked at the actual ports on the back?
"USB cable
The manual says USB2.0 *Type A/B* which is the squarish one (Not the USB2.0 rectangular one)
My 6-feet USB2.0 to USB2.0 cable end is both rectangle (not square Type A/B)
Did i buy the wrong cable?
