[SOLVED] "Driver-Power-State-Failure" BSOD occurs on my laptop due to graphics card
Feb 9, 2022
As the title of the question suggests, I'm having an issue with my laptop regarding my graphics card and the BSOD. I have a big feeling the issue has to do with my Nvidia graphics card, as when I open device manager and check the display adapters, when my GPU is there, my computer shortly BSOD itself later, and when I check the device manager again, my Nvidia GPU is not there anymore. The computer works fine after the restart caused by the BSOD as well. Also, when I play a game while my Nvidia GPU is on, it will stall the BSOD before it happens. I think this is due to the GPU being utilized, and when it isn't, it crashes after some time. I also want to mention when I shut down my laptop and turn it back on after a while, my GPU will show up again on the device manager. But again, it will BSOD and stop showing up after the restart. Help me out!
Specs:
Laptop Model: Asus ROG GU501GM
Processor: Intel(R) Core(TM) i7-8750H CPU @ 2.20GHz 2.21 GHz
Installed RAM: 32.0 GB
GPU: GTX 1060
I would run DDU in safe mode, remove the current Nvidia drivers
and install the latest from here and see if you still have issues - https://www.asus.com/supportonly/GU501GM/HelpDesk_Download/
Reactions: enlightener
It seems like my computer works, but when I restart it or shut it down, it takes a while before it does, and then I get BSOD'd. Hey, at least it's not happening like the way it was before. We'll just say this problem has been solved for now. Thanks!
