M mooja14 Reputable Dec 7, 2015 3 0 4,510 Dec 7, 2015 #1 So, I have 2 monitors, each have 1 VGA port, and 1 DVI port. My custom build PC has 2 DVI ports and an HDMI port. What is the best method for hooking up both monitors? I already tried two DVI cables, and that didn't work.
Solution kanewolf Dec 7, 2015 You already tried the best method. You need to determine why if failed. DVI is the best connection alternative for your situation.
kanewolf Titan Moderator May 29, 2013 37,326 3,277 156,790 Dec 7, 2015 Solution #2 You already tried the best method. You need to determine why if failed. DVI is the best connection alternative for your situation. Upvote 0 Downvote Solution
M mooja14 Reputable Dec 7, 2015 3 0 4,510 Dec 10, 2015 #3 I was just dumb. I had 1 DVI and a VGA cable plugged into a DVI adapter. User error issue. Upvote 0 Downvote
