Question Dual monitor
John_632
Commendable
Feb 5, 2017
21
If I were to connect 1 monitor hdmi to hdmi and another mini dp to hdmi would I have two separate outputs or have one cloned screen output
I think the question was did you want the same image on both displays or separate images. This is controlled through your graphics card control panel. Once both displays are connected to the graphics card, open the control panel and you should find a setting or option for setting up multi-displays. The same image on both displays is the "Cloned" setting while different displays on each monitor would be the "Extended" setting.
-Wolf sends
