[SOLVED] Enough PSU power?
just_afkej
17
Will 400W PSU be able to handle the following:
Kingston HyperX Fury, DDR4, DIMM, 3200MHz, 16Gb(2x8). CL16, Intel XMP, black
Asus Prime B450M-K II
AMD Ryzen 7 1700, BOX, Wraith Spire cooler
Nvidia GeForce 1050Ti
2HHDs and 1SSD disks?
It's debatable.
It's likely though. My computer is a 7 year old HP Z220 SFF Workstation with an Intel I5-3470, Nvidia GeForce GT 710, WDC-WD10EZEX 1TB HDD, and some juicy RAM and a decent Wifi card, while only using 240W. The main power hog is the CPU, as mine can consume up to 80W.
It is written on it that it is Seasonic, cant see something else that will say more( i mean like full name)
I'm just curious if i need to buy a new PSU or this one will handle it or i need like 500W or,.
It's debatable.
btw, will ryzen 7 1700 fit onto Asus Prime B450M-K II ? I'm just curious because it says on mobo that the socket is B450, but at the same time it says that AM4 (ryzen 7,.) should fit aswell?
