I have built have new PC and Im having a few erratic problems (this problems have not been happening everyday).
The first problem that I had, was with memory cards where I had several blue screens (MEMORY MANAGEMENT , IRQL_NOT_LESS_OR_EQUAL) with indication of memory management problems. I executed the windows memory diagnostic program and it detected hardware issues. Afterwards, I used only one stick (I have two) and the memory diagnostic was Ok this time. Then I inserted the two memory sticks back again and problem was fixed.
A few days later, there was a problem with the Ethernet port not being detected by the OS (Windows 10) and there was no light in the physical component. After connecting the ethernet cable a few times, it finally detected the cable and the Ethernet port lighted up, and the internet connection was working again.
Another problem I had was with my AMD graphics card, it was not being detected and the built-in motherboard card was being used. I uninstalled and installed the graphics drivers back and it graphic card was detected again.
Now, sometimes when I put the PC in sleep mode and I start it back up again it lights up but the Windows sessions does not start (black screen).
What could be the cause of this? Below is the system information:
CPU: AMD Ryzen 7700x
GPU: AMD Radeon RX 6650xt PowerColor Hellhound
RAM: 2x16 Kingston Technology FURY Renegade 32GB (2x16GB) DDR5 6400MHz CL32 (It is currently working at 4800Mhz)
CPU Cooler: Cooler Master Hyper 212 Black Edition with LGA1700
Motherboard: ASUS PRIME X670-P AMD X67 AM5
PSU: LC-Power LC6650GP3 V2.3 230V 650 W 80+ Silver Certified ATX Power Supply
BIOS Version: 0809 (out of date)
Thank you.
Thank you.
