[SOLVED] Ethernet connection problems - Please help!
May 26, 2020
20
Hi everyone. I recently decided to get my new PC hooked up to ethernet. I plugged it into the port and it worked at first, but after I changed some settings, it refused to show up. It would not show Ethernet in the connectiond tab. For those of you wondering, this is the guide I followed for better latency.
View: https://www.youtube.com/watch?v=9OfzAiCX7XI&t=302s
( If somone is going to roast me for it being Fortnite related, I don't play fortnite, I just found this as a guide )
The timestamp for the settings I changed is 4:47 and it shows how to get into the settings at 4:07
I'm not sure if it was just that the connection quit before this, and I hadn't realized (a problem with my router) or that these settings could have screwed something up. I'm fairly sure that even if I did do something wrong, it wouldn't kick me off the Ethernet altogether, rather just have problems with getting a actual connection. Could my cable be messing something up? Are the settings that the guy recommends (some of them I didn't have so I didn't have, and there were also ones that he had and I didn't, so I just decided to leave those alone) harming my connection? If the settings are wrong, there is no way I can revert them, as the ethernet doesn't show up anymore. I'm no expert in internet connections, so I apologize if I'm missing something obvious.
Thank you and have a good day!
These videos are typically hyped nonsense made by people who are making money off of the viewers viewing the aforementioned nonsense.
My guess is that you messed up your settings. If you can get back into them, set it to default and then don't mess with them.
