Initially my internet was cutting out completely (would just shut off) for just a second randomly. Sometimes it would happen in bursts, sometimes it would only happen once. So I replaced the modem (It's just Comcast's default modem) and replaced the cable leading to the house. Upon doing that it weirdly both fixed the problem and didn't. I'm unsure if this is the same problem in a different form or a separate issue.
I'm a live streamer, and I would not have noticed this if I was not. Randomly my internet will (based on the task manager statistic) go from the normal 20-30 mbps upload all the way down to 100 kbps and then shoot back up. Within one hour I dropped ~25,000 frames. And then randomly around 12:30-1 AM EST it'll just stop and be completely stable for the rest of the evening. So I don't know if it's caused by the increased activity or if it's just focused around that timeframe. I'm partial to think it's the timeframe (11 PM-1AM EST) as I have started streaming at different times with no issue. I have been streaming for upward of two years on this exact setup with no issue.
The way my setup works is: Modem connected to external power supply connected to PC. I have replaced the modem (and the cable leading to the house), I have replaced the shorter ethernet cable, and I have plugged the longer ethernet cable directly into my PC eliminating the external power supply from the equation.
I have also refreshed my IP, and flushed DNS.
I am willing to try literally anything.
Now I will answer every "DO" in g-unit's post.
Please help. 😓
- The router/modem is just the default one Comcast gives you, I don't know it's exact name.
- These are my specs: https://pcpartpicker.com/user/Insayno/saved/BQqsZL + Windows 10
- I have many devices, I think 9, but again it's never been an issue before.
- I have not received any error messages.
- I don't use any switches?
- My PC is the only one with a wired connection to the modem.
- No server is connected but TBH I don't know what NAS is.
- I believe comcast's modem is both a router and modem.
- I am using the motherboard LAN connection but I am willing to get an adapter if that is the issue, but as I've had this system for years and nothing has changed I don't see how it could be. Who knows, technology is weird.
Please help. 😓
