Hi all ! I am looking to replace the stock 120mm tri-cool fans in my antec p180 case. The model I am looking at are Noctua, Scythe and SilenX.
I am looking for both silence and relatively high CFM. The fans will be controlled by a Sunbeam Rhoebus Extreme 6 fan controller.
I am opened to suggestions from other brands and comments on the fans I've mentioned above.
And also if you have the same case I do and you've replaced the stock fans let me know wich ones you chose and tell me about the results !
Thx !
Thx !
