So I've decided to take the clock settings a little on this, to 790/1000. Decided to stick to overdrive. And I noticed the temps being higher than they can be with fan setting at auto. So I turned manual on and made it run at 33% because that was the sweet spot for noise and speed and it helped temps quite a bit. Auto speed only ran up to 22% speed at max for some reason at temps around high 70s to low 80s. I guess its not high enough to run faster.
I'm wondering if its safe to leave it at manual 33% speed? I'm worried that SOMEHOW, I DONT KNOW EXACTLY HOW BUT SOMEHOW, the card decides to heat up a bit and the 33% fan speed isnt enough then bam crash. While the auto fan control seems more reliable, it doesn't exactly give the best cooling, and I don't want the thing to run at higher speeds since it gets pretty loud.... any comments or recommendations are appreciated.
(my english must sound really broken up right now... lol sorry, tired).
