So i am planning on buying a Lian Li Lancool 2. It comes with 1 120mm front fan for intake and 1 120mm back and 1 120mm top fan for exhaust. Do I need to buy any extra fans for good airflow or are the stock ones sufficient?
usually its depends on the components that you choose within the computer. IMO i would say only when looking to OC enthuiast components will case airflow be majorly important. As long as youre not stuffing massive components into a mini case. theres a fair amount of space between components and theres at least 1 rear fan. you should be good.
