Question Fing Warning - You have connectivity problems.
JUDGE DREDD2013
26
Fing is showing the warning You have Connectivity Problems - Ethernet link speed is not optimal.
I am running Windows Ten Pro 64. The Router is a PlusNet Hub 2 . The adaptors in PC are Gigabit Network Connection.
Any ideas how to fix this? Thanks
What is the link speed? 1000 or 100? If it is 100 then you need to replace the cable, because that is the most common reason for 100Mbit link. If you have any in-wall wiring, that is also a very common problem area.
You say you have a PlusNet Hub Two. That should have gigabit LAN ports.
