ANTEC Black Solution Series ATX Mid-Tower Case with 350W Power Supply, Model "SLK3700-BQE" -RETAIL
Specifications:
Case Type: Mid-Tower
Color: Black
Material: Steel
Drive Bays: 5.25'' x4,3.5''(External) x2,3.5''(Internal) x4
Expansion Slots: 7
Front Ports: USB2.0 x2
Power Supply: 350W
Cooling System: 120mm x1
Motherboard Compatibility: Standard ATX
Dimensions: 18.3''Hx8.25''Wx18.6''D more info>
N82E16811129140 $74.00
$74.00
CD/DVD Burners (RW Drives)
Lite-On Black 52X32X52 CD-RW Drive, Model LTR-52327S, OEM
Specifications:
Write Speed: 52X CD-R, 32X CD-RW
Read Speed: 52X CD-ROM
Interface: ATAPI / E-IDE
Buffer: 2MB
OS Support: Windows 95/98/NT/ME/XP/2000
Features: Innovated SMART-BURN technology
Remark: OEM pack (see pictures for details) more info>
N82E16827106197 $35.50
$35.50
CD/DVD ROM Drives
Lite-On Black 16X DVD-ROM Drive, Model XJ-HD166, OEM
Specifications:
Read Speed: 48X CD-ROM, 16X DVD-ROM
Interface: E-IDE/ATAPI
Buffer: Not specified
Access Time: 120ms ( typical )
Data Transfer Rate: DVD-ROM 8600~21600 KB/sec, CD-ROM 3000~7200 KB/sec
Features: SMART-X Technology, Easy-Tray Design for Both Horizontally & Vertically Use
Remark: OEM (see pictures for details) more info>
N82E16827131603 $29.00
$29.00
Hard Drives
Maxtor 120GB 7200RPM IDE Hard Drive, Model 6Y120P0, OEM Drive Only
Specifications:
Capacity: 120GB
Average Seek Time: 9.3 ms
Buffer: 8MB
Rotational Speed: 7200 RPM
Interface: IDE ULTRA ATA133
Features: Maxtor Shock Protection and Data Protection Systems
Manufacturer Warranty: 3 years
Remark: OEM Drive Only more info>
N82E16822144148 $96.50
$96.50
Memory (System Memory)
Corsair Value Select Dual Channel Kit 184 Pin 1G(512MBx2) DDR PC-3200 - OEM
Specification
Manufacturer: Corsair
Speed: DDR400(PC3200)
Type: 184 Pin DDR SDRAM
Error Checking: Non-ECC
Registered/Unbuffered: Unbuffered
Cas Latency: 3
Support Voltage: 2.5V
Bandwidth: 3.2GB/s
Organization: two 64M x 64 -Bit
Warranty: Lifetime more info>
N82E16820145480 $168.00
$168.00
Motherboards - AMD
ASUS VIA K8T800 Chipset Motherboard for AMD Socket 754 CPU, Model "K8V SE Deluxe" -RETAIL
Specifications:
Supported CPU: Socket 754 for AMD Athlon 64 Processors
Chipset: VIA K8T800 + VT8237
FSB: Hyper Transport
RAM: 3x DIMM for DDR400/333/266 Max 3GB
IDE: 3x ATA 133(1 from Promise 20378) up to 6 Devices
Slots: 1x AGP 8X, 5x PCI, 1x Wi-Fi
Ports: 2xPS2,1xCOM,1xLPT,8xUSB2.0(rear 4),1xLAN,2x1394(rear 1),SPDIF Out,Audio Ports
Onboard Audio: AD1980 6-Channel audio CODEC
Onboard LAN: Marvell GbE
Onboard SATA/RAID: VT8237, 2xSATA, RAID 0/1; Promise R20378, 2x SATA, RAID 0/1/0+1
Onboard 1394: VIA VT6307, 2x 1394
Form Factor: ATX more info>
N82E16813131490 $144.00
$144.00
Processors
AMD Athlon 64 3000+, 512KB L2 Cache 64-bit Processor - Retail
Specification
Model: AMD Athlon 64 3000+
Operating Frequency: 2GHz
FSB: Integrated into Chip
Cache: L1/64K+64K; L2/512KB
Voltage: 1.5V
Process: 0.13Micron
Socket: Socket 754
Multimedia Instruction: MMX, SSE, SSE2, 3DNOW!, 3DNOW!+
Packaging: Retail Box (Heatsink and Fan included) more info>
N82E16819103424 $224.00
$224.00
Sound Card
Creative Labs Sound Blaster Audigy2 ZS PCI Sound Card, Model "SB0350" -RETAIL
Specifications:
Channels: 7.1
Max Sampling Rate: 192kHz
Signal-Noise Ratio: 108dB(SNR)
Hardware Decode: Dolby Digital EX
Digital Audio: 24-bit
Hardware Polyphony: 64 Voices
PC Interface: PCI
Connectors: Line-out, Line-in, Mic-in, Digital Out(5.1), Firewire(IEEE1394), Analog/Digital CD Audio in, Telephone Answering Device in, GAME/MIDI port via extension header, Internal IEEE1394 header and AD_EXT extension header to Audigy 2 ZS Internal I/O Drive(See Details)
External Box: N/A
Remote Control: N/A
Special Features: DVD Audio, THX certified, EAX more info>
N82E16829102162 $88.25
$88.25
Video Cards
SAPPHIRE ATI RADEON 9800PRO Video Card, 128MB DDR, 256-bit, DVI/TV-Out, 8X AGP -BULK
Specifications:
Chipset/Core Speed: ATI RADEON 9800PRO/380MHz
Memory/Effective Speed: 128MB DDR/680MHz
BUS: AGP 1X/2X/4X/8X
Ports: VGA Out(15 Pin D-Sub)+TV-Out(S-Video Out)+DVI Connector
Support 3D API: DirectX®9, OpenGL®2.0
Cable/Accessories: 4 Cables, VGA via DVI Adapter, PowerDVD, Driver CD
Max Resolution@32bit Color: 2048X1536@85Hz more info>
N82E16814102268 $211.00
$211.00
Extend my Standard Warranty on the above qualified items: $64.22
Subtotal » $ 1,070.25
Shipping and Handling Charge »
Tax Instruction for All Resellers How Newegg.com calculates shipping $
FedEx International Economy - PR ONLY APO/FPO - Military ONLY FedEx Standard Overnight FedEx 2Day FedEx Express Saver Choose which State to ship AA AP AE ALASKA ALABAMA ARKANSAS ARIZONA CALIFORNIA COLORADO CONNECTICUT DISTRICT OF COLUMBIA DELAWARE FLORIDA GEORGIA HAWAII IOWA IDAHO ILLINOIS INDIANA KANSAS KENTUCKY LOUISIANA MASSACHUSETTS MARYLAND MAINE MICHIGAN MINNESOTA MISSOURI MISSISSIPPI MONTANA NORTH CAROLINA NORTH DAKOTA NEBRASKA NEW HAMPSHIRE NEW JERSEY NEW MEXICO NEVADA NEW YORK OHIO OKLAHOMA OREGON PENNSYLVANIA PUERTO RICO RHODE ISLAND SOUTH CAROLINA SOUTH DAKOTA TENNESSEE TEXAS UTAH VIRGINIA VERMONT WASHINGTON WISCONSIN WEST VIRGINIA WYOMING
Grand Total » $ 1,070.25
