http://uk.pcpartpicker.com/p/QW4Pgs
Here is a list of parts I'm thinking of using in a build (my first build) for later this year. I'd like some advice on whether or not I should change some of the parts.
I don't need a monitor, mouse or keyboard the upper limit for my budget is around £850-900
I won't be overclocking, but chose the hyper 212 because it'll be much quieter than the stock cooler. I also won't be using crossfire or SLI in future.
I'll be using it for gaming at 1080p, as well as some light video converting (just changing formats and resolution of videos). I'll be playing games like AC4, BF4, and a load of other less intensive games. Not too bothered about AA, but would like to play using at least high settings.
Should I use an i5 4440 instead of a 4570?
Is an ssd *really* worth it? Or should I just get a 120GB ssd? It'll mainly be used for the OS, programs and a few of my most played games.
Could anyone also recommend me a decent case for this build? I chose the 500r because of the good airflow and cable management, as well as the removable/modular hdd trays, but I'm still not decided on which case I should use.
Any advice is much appreciated
Note: recommended parts should preferably be available on amazon (also preferably sold directly by amazon)
