First build opinions?
Oct 1, 2019
Hey everyone, this is going to be my first build, sort of a mid range build. I'd like to know your opinions on it, if it's a solid build, if you'd change anything or add.
Thanks in advance!
AMD RYZEN 5 3600x Wraith Stealth
Gigabyte GeForce® RTX 2060 SUPER Windforce OC 8GB GD6
Corsair TX650M 80 plus Gold
Corsair Vengeance LPX 2 x 8gb DDR4, 3200Mz C16
Seagate Barracuda 1TB 7200RPM 64MB SATA III
Crucial MX500 250GB 3D SSD
Motherboard MSI B450 MORTAR MAX mATX
TP-Link PCI Express Dual Band AC1300 Archer T6E
Phanteks P400 grey case
Hi, that looks like a very good build. You could drop to a 3600 instead of the 3600X as the difference is not great at all and if you are happy to overclock you can make up the difference, the money saved can go to a NVMe M.2 SSD. They are a little more in price but for 250GB you are looking at around $40+ and currently the Intel 660p 500 GB is $65...
Reactions: ExGordo
Just as an example with a 3600 and X570 ASRock motherboard with RTX 2060 Super...512GB NVMe M.2 SSD and 1TB HD...
PCPartPicker Part List: https://pcpartpicker.com/list/bnh99G
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor ($194.79 @ OutletPC)
Motherboard: ASRock X570 Phantom Gaming 4 ATX AM4 Motherboard ($148.99 @ Amazon)
Memory: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3200 Memory ($74.99 @ Amazon)
Storage: ADATA XPG SX6000 Pro 512 GB M.2-2280 NVME Solid State Drive ($59.99 @ Amazon)
Storage: Western Digital Caviar Blue 1 TB 3.5" 7200RPM Internal Hard Drive ($42.89 @ OutletPC)
Video Card: Gigabyte GeForce RTX 2060 SUPER 8 GB GAMING OC Video Card ($409.99 @ Newegg)
Case: Phanteks Eclipse P400 ATX Mid Tower Case ($74.99 @ Newegg)
Power Supply: EVGA GD (2019) 600 W 80+ Gold Certified ATX Power Supply ($64.99 @ Amazon)
Total: $1071.62
Generated by PCPartPicker 2019-10-01 06:31 EDT-0400
Total: $1071.62
Thanks man, but the crappy part is that I live in Europe, everything is a lot cheaper in the US with a lot of deals, here not so much
Bad advice with the new AMD systems you’re better of letting the CPU boost itself opposed to overclocking. If you’re rendering video etc then OCing is good but not for gaming.
Also if you’re not interesting in RTX or PhysX the 5700XT is a better buy than the 2060 Super
Aha I see, yep, prices are so different depending on where you are. As to the 3600 over the 3600X, I would still say the 3600 as it is so, so close to the 3600X across the board and the money saved (unless the price is very close) can go towards a better or bigger SSD for your boot drive.
Around 55$ more
