Hello all, I've done lots of research and I *think* I have a pretty decent $1000 build picked out, but since I've never done any work on PCs before there is a distinct chance that when I put it all together it will burst into flames. Please take a look at my selections and favor me with your sage wisdom.
Case: NZXT Apollo (it comes with rear and side 120mm fans and I'll be purchasing a 3rd to go in front)
http://www.newegg.com/Product/Product.aspx?Item=N82E16811146025
CPU: Intel i5-2400
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115074
Motherboard: ASRock Z68 Pro3
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157251R
RAM: Corsair Vengeance 16GB (4 x 4GB) 240-Pin DDR3 1600
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145347
HDD: Western Digital Caviar Blue 1TB
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=7288051
Thermaltake Silent 1156 Heatsink/fan
http://www.newegg.com/Product/Product.aspx?Item=N82E16835106139
The only parts I'm not sure about are the GPU and PSU. For the video card it's between the
EVGA GTX 550 Ti http://www.newegg.com/Product/Product.aspx?Item=N82E16814130625
and the ASUS GTX 550 Ti. http://www.newegg.com/Product/Product.aspx?Item=N82E16814121434
They are the same price, and as far as I can tell pretty much identical. Does one have any benefit over the other, or is this more of a brand preference thing?
And as for the PSU, should I go for the less expensive, minimum wattage like the Corsair CX430 http://www.newegg.com/Product/Product.aspx?Item=N82E16817139026&Tpk=corsair%20cx430
or should I invest in something better in case I want to upgrade to multiple graphics cards in the future, like the Corsair GS600?
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139023&Tpk=corsair%20gs600
I mostly plan on using this for gaming, things like WoW, Mass Effect, Dragon Age, Sims, etc., watching movies, light internet browsing, and relieving my overburdened laptop. I don't think I'll ever do any overclocking. I may add in things like Photoshop later, but only for my own amusement. I'll be getting a Blu-Ray combo drive like the ASUS BC-12B1ST, Windows 7 Home Premium, and I'd like to use dual monitors, maybe these http://www.newegg.com/Product/Product.aspx?Item=N82E16824236079
I'll have to buy everything over the course of a few weeks, but I should be able to squeak by at just over my $1000 budget.
Let me know if I've made any beginner mistakes, such as choosing parts that won't work together 😛 . Thoughts, opinions, and insights are all welcome. Thanks in advance!
CPU: Intel i5-2400
