I'm looking to build my own PC for the first time since my current computer is fairly outdated. I'm looking to build something around the $800-900 usd range. I already have keyboard,mouse,monitors,2HDDs of 500GB.
PC usage-college work and a little gaming on the side
This is what I've come up with:
pcpartpicker.com
CPU: Intel Core i5-11600 2.8 GHz 6-Core Processor
CPU Cooler: Deepcool AS500 Plus 70.81 CFM CPU Cooler
Motherboard: Gigabyte B560 AORUS PRO AX ATX LGA1200 Motherboard
Memory: G.Skill Ripjaws V Series 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory
Storage: Western Digital Blue SN550 500 GB M.2-2280 NVME Solid State Drive
Case: Fractal Design Meshify C ATX Mid Tower Case
Power Supply: Corsair RMx (2018) 750 W 80+ Gold Certified Fully Modular ATX Power Supply
Case Fan: Adata XPG Vento Pro 120mm
I also plan to buy a decent gpu once the market stabilises
I don't know much about computers so I'm just wondering if anyone more knowledgable could tell me if there is any issue with the build or not (maybe if you think I should spend more money in a certain area and less in another or something like that).Most importantly i want stable system to last me 5-6 yrs.
1.Is the cooler good enough?is noctua nh-u12s also enough ??Plz recommend any other air cooler if cooler needs a change(not comfortable with AIOs)
2.Should i go with i5 11600k but isn’t it too hot ??
3.Should i go with mATX board??(mATX board runs hot as compared to ATX)
4.Should i go with wd blue sn550 1tb or samsung 970 evo 500 gb nvme ssd?
5.should i go with corsair vengeance lpx(2*8)16 gb ddr4-3200 cl 16 memory kit?
6.I also am not sure if all the parts are compatible or not? (although PC Part Picker indicates that they are). Any advice is really appreciated
Thank you in advance 🙏🏻🙏🏻
System Builder
