[SOLVED] First Pc build
SpacEagle17
44
Hi, I want to ask you guys if the components I choose for my first build are good. My budget is between 400 and 480. I buy just from amazon. I live in Germany. I want to browse on the Internet, watch Youtube videos and play games like Minecraft. I use actually a laptop with the intel core i3 6006u with integrated graphics intel hd graphics 520, the laptop has only a 500gb HDD, so it's a big jump from my laptop to this pc.
Specs:
Motherboard: MSI B450M PRO-VDH MAX
CPU + GPU: AMD Ryzen 3 3200G
RAM: Corsair Vengeance LPX 16GB (CMK16GX4M2D3000C16)
SSD: WD Blue (WDS500G2B0A)
Wifi + Bluetooth: Ubit wifi card (E03H-WIE9260)
Power supply: corsair cx 550
Case: Sharkoon VG4-W Red
fan 120mm 4 pin: sillent wings 3 x2
View: https://www.youtube.com/watch?v=oC6CxTxat74
Thank you for your help
Just looking on German Amazon
1600 - €109
Gigabyte B450m s2h - €60
16gb corsair 3000mhz - €75
Xfx ex 570 4gb - €129
Thermaltake smart rgb 500w psu - €47
=€420
Can get a wifi dongle for €8, 128gb ssd boot drive for €20, 500gb seagate hdd for €16.50.
Leaves about €20 for a case which is possible.
Unless you really want an apu build you might want to play around with a build like this see if you can get it any cheaper.
1600 - €109
=€420
