Build Advice First time build advice
Jun 11, 2019
Hi everyone
I am a first time builder and poster seeking a bit of input in regards to my build that I have started predominantly for gaming.
CPU: Intel i5 9600k
Motherboard: Asus ROG Strix Z390-H
GPU: ASUS ROG Strix RTX 2060 OC
Case: EVGA DG-87
CPU Cooler: EVGA CLC 280mm Liquid Cooler
Power Supply: Corsair RM750x
RAM: G.Skill Ripjaws 16gb 2400mhz
SSD and HDD will be taken from previous desktop
I am pretty confident in regards to compatibility however can someone please confirm that the PSU is sufficient and that the build should work?
Thanks in advance.
RM750x is definitely more than sufficient, but I would say it might be a bit over the top, you should be able to run that system comfortably on an RM550x or 650x. Are you planning on overclocking? If not I wouldn't bother with the liquid cooler, something like a Noctua DH-14, be quiet Dark Rock Pro 4 would be perfectly fine even if you are overclocking or even a Hyper 212 would be ok at the budget end. Then you might be able to stretch to an RTX2070 which is a big step up. And get faster RAM, there very little difference in price between 2400/2600/3000Mhz, it's not going to make a huge difference, but when the difference is between $60 and $65 it just future proofs you a little bit more.
Thanks for the feedback everyone.
I will upgrade the ram to at least 2666 if not 3000mhz. Overclocking wise yes I was hoping to do so just to keep it longer and at a higher clock. GPU wise I was split with the 2070 but got a great price for the Strix 2060.
