Fix for small silicon insert
TheMajesticBurger
137
I have Alphacool 16mm OD 13mm ID acrylic tubing, and a Alphacool 13mm silicon insert.
When I am bending tubes there is about a 1mm to 2mm gap between the insert and tubing, and it is messing up all of my bends. Is there a way to fill in the unfilled gap of air? Or did I just get a messed up insert?
lumineZ
Estimable
Jul 25, 2017
1,747
383
If there is 1 - 2mm gap either your insert or the tube is messed up. Have you tryed other tubes just to check?
No good solution when the insert is to small besides than getting a new one.
You can try to add more heat and be super carefull and slow while you bend, and dont bend so sharp.
lumineZ
Estimable
Jul 25, 2017
1,747
383
TheMajesticBurger
137
Yes, they all have about 1-2mm maybe even 4mm, idk. The gap looks thicker than the tube wall, lol
lumineZ
Estimable
Jul 25, 2017
1,747
383
holy... Not to step on anyone`s toes in here but this is YET an example why I stay far, far, far away from Alphacool products...
First messure the diameter of the silicone insert just to make sure its correct, and that you have not gotten one that is 10mm or something, then messure the ID on the tubes to see if they are idd 13mm and not like 15mm
If your silicone is correct but tubes and not, just return the tubes for new ones or refund.
TheMajesticBurger
137
Silicon inside tubing:
http://imgur.com/a/eWkUw
Measurement of silicon:
http://imgur.com/a/G0lkk
Measurement of Tubing:
http://imgur.com/a/0SXSo
I brought a pack of 4 tubes, and I already used 1.5 tubes, so no return for me :(
lumineZ
Estimable
Jul 25, 2017
1,747
383
From what I can see on the pictures you have a 12mm silicone insert ment for 12mm ID... So looks like you got the wrong one.
I can messure my inserts tomorrow just to verify the messurements.
TheMajesticBurger
137
The packing says 13mm.
lumineZ
Estimable
Jul 25, 2017
1,747
383
What is says and what it is... thats 2 different things. I once ordered a 12mm from barrow and got 8mm....
So I have just learned to messure everything even if it reads XX mm on the box
TheMajesticBurger
137
I'm just going to buy 90 degree and 45 degree fittings for the components only, so I wont have to do that many 90 degree bends.
