Question FPS DROPS/LAGS/ RUNNING OUT OF VIRTUAL MEMORY CRASHES
LiveIsCruel
29
Hello,
I have a lot of problems in games like COD CW, EFT, SQUAD and Hell Let Loose with huge fps drops and freezes. GPU temps around 80 degrees CPU around 50. This all is starting from little freezes and leading to the crashes, doesn't matter if I shoot or do nothing games are randomly freezing. I'm obsessed with having the latest drivers and bios installed as well as windows updates.
Also in COD CW every map I play on I have following error:
Faulting application name: BlackOpsColdWar.exe, version: 1.0.0.0, time stamp: 0x6038188f Faulting module name: BlackOpsColdWar.exe, version: 1.0.0.0, time stamp: 0x6038188f Exception code: 0xc0000409 Fault offset: 0x000000000c84b304 Faulting process ID: 0x33ac Faulting application start time: 0x01d70f99b3aed127 Faulting application path: D:\Call of Duty Black Ops Cold War\BlackOpsColdWar.exe Faulting module path: D:\Call of Duty Black Ops Cold War\BlackOpsColdWar.exe Report ID: 8dbbfa3d-4236-421d-b538-a1a16d898631 Faulting package full name: Faulting package-relative application ID:
Things I tried:
-Clean gpu drivers install
-Bios updated -
-Removed oc from gpu
-No oc on cpu apart from pbo
-Installed games to ssd and m2 nvme
My config:
-GPU: RTX 2060 6GB
-CPU: RYZEN 5600X
-RAM: 16GB 2666MHZ
-MOBO: ASUS B450M-A
Hope someone will help me with this one as it is very frustrating as the games are not playable. Thank you.
Little update I have found something like this in Event Viewer:
Windows successfully diagnosed a low virtual memory condition. The following programs consumed the most virtual memory: BlackOpsColdWar.exe (13228) consumed 32544686080 bytes, opera.exe (4448) consumed 396877824 bytes, and MsMpEng.exe (4048) consumed 261623808 bytes.
