Start with what essential hardware I am currently running:
Foxconn K8S755A-6ELRS Socket 754 SiS 755 Motherboard
AMD Athlon 64 3200+ Socket 754
ZALMAN 600W Power Supply (Modular)
Western Digital Caviar 160GB 7200 RPM SATA
Western Digital Raptor 74GB 10,000 RPM SATA
2x 512mb + 1gb of Corsair Value Select DDR400
HIS Radeon X1950PRO 512MB 256-bit GDDR3 AGP 4X/8X
O/S = XP 32bit SP2 updated.
Problem: My frames per second are not at all what they should be. Examples. Hitman Blood Money (unplayable) Counter-Strike : source (30fps average...) and these are with ABSOLUTE LOW settings. Weird thing is I can crank them up to higher resolution and medium/high settings (kind of settings I should run normally) and it stays about the same...its like my FPS is being capped (or bottlenecked) to a point.
Solutions Tried:
Ok I have tried reformatting
Latest Drivers/Updates
The only thing I can think of is the motherboard cause it is the only real new thing I've installed...and I already have problems with the harddrive controler.(most the time when I reboot it wont even see any my harddrives, I have to do a warm boot)This motherboard was just a replacement, it needs updated...the bios on this thing hasn't had a revision sense 2005.
Solutions Tried:
