Question freenas problem
dmmass
24
So i want to install freenas on an old pc but i cant seem to install it. I've tried installing it on hdd and on an ssd (tested and working fine). The freenas image is on a cd becouse the board wont boot from usb. The strange thing that happens is the install steps start 1of 4 and the system turns of randomly, sometimes on 40% sometimes on 80% all on step 1 of install. After that i need to reformat the drive because then when i try to install it instantly says install failed. I have noticed some error while freenas loads, here they are. The specs of the pc are as follows, and this is not the final build. Mobo: supermicro pdsma+ , 2gb ddr2 RAM, wd blue 240gb and kingston a400 120gb ssd, pcix supermicro controller (sat2-mv8 for extra sata ports) intel celeron (64bit cant remember bu i also have a core 2 duo 4300).
Additionally, your RAM is woefully inadequate.
Officially, FreeNAS requires 8GB minimum
Will it run on less? Maybe. But 2GB is almost certainly not enough.
i have seen people run on 2 gb of ram, i initiali want to see if everything works and when i add my drives ill just add more ram
