freezing up problem
G
Guest
Guest
I have a 700mhz amd thunderbird on a asus a7v and it keeps my system freezes on me randomly I did have a conflict with my sb live card in slot 3 but fixed that. but it is still freezing here are two things it does 1st when I boot some times it freezes once windows is loaded with a green bar along top of my screen. the other times it freeze after I have suffed or even played a couple of games I am able to alt-ctrl-del to reboot anyone else have this kind of trouble and know how to fix it Thanks for any help possibale
I had the same problem. However i discovered that pushing in all my hard disk cables made it happen much less (happened once since). I read somewhere that the greenlines show that a removable hard disk isnt fully in so thats where i got it from. Hope it helps or has anyone else any ideas?
KK
Please dont hurt me.....please
Thanks never thought of that but I did OverClock my 700 to 900 and boosted the voltage to the core up to 1.85 that seemed to help to have not had that trouble since I did that taking computer apart to push in cables once again thanks
