Hello all,
I recently completed my build (the mid level one: http://lifehacker.com/5840963/the-best-pcs-you-can-build-for-600-and-1200). After installing all the drivers and everything else working perfectly, I have found out that my front audio jack isn't working 🙁 I've made sure that the headphones are not muted in the lower right hand corner icon. I went to the BIOS screen and found out that even with my headphones plugged into the jack, I have found out that in the BIOS screen of my ASROCK Z77 extreme 4 motherboard it says that they are unplugged. I looked inside the case to make sure I plugged in the audio jack to the motherboard, and I have. I've looked at the other posts with the same problem, and nothing seems to fit. Help!
Build information:
-Windows 8 pro (64bit)
-NZXT Elite 210
-ASROCK Z77 Extreme 4 motherboard
-Intel i3 processor
-Samsung SSD 840 Pro
-8 GB G. Skill ram
-Geforce GTX 560 SE graphics card
Build information:
-NZXT Elite 210
-Intel i3 processor
-8 GB G. Skill ram
