Hi, on my motherboard (AsRock B450M pro4-f), I don't know how to connect the reset switch and the power switch, so can you say me if I have to connect it like on the image 1 or on the image 2 ?
And should i connect the PWRBTN# and the RESET# on the positive side of my pins (where i can see a little triangle) or it would work no matter where I put the little triangle?
Image 1 :
Image 2:
Thank you!
Image 1 :
Image 2:
Thank you!
