G
Guest
Guest
Archived from groups: rec.games.video.arcade.collecting,rec.games.video.arcade.marketplace (More info?)
I have one of the 96-in-1 multipacman kits and an Original Midway Ms.
Pac-Man PCB I would like to sell as together. The kit is uninstalled and
brand-new (I also think there is a recent ROM update available to play
superpac, but this is the relaese just prior to that addition, but it could
be easily updated) and the PCB was functional when last tested, but I no
longer have a pac to test it in. The pcb has also been modded slightly to
use a DC switching power supply, with leads soldered directly on the board,
ending in a quick connect plug for attaching to leads from a standard
switching power supply. If you want to use it with the original power set up
(AC) you would need to resolder a pair of resistors that have been
disconnected but are still intact. I did not do this mod, it came done to a
couple boards I got with the pac machine I had, but it was skillfully done
and seemed quite reliable.
I'd like $230 for the set (PCB and 96 in one kit w/ ribbon cable) with
shipping in the USA included. LMK if your interested, paypal
preferred. -Joshua
Remove NOSPAM from address when emailing a reply (atariNOSPAM@twcny.rr.com)
preferred. -Joshua
