GA-7N400 Pro 2 - Gigaraid Function
G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.giga-byte,alt.comp.periphs.mainboard.gigabyte,alt.comp.periphs.gigabyte (More info?)
Hello
I have a Gigabyte GA-7N400 Pro 2 motherboard and would like to set up
the Gigaraid function using 2 Maxtor 40 gig ata/133 drives. One has xp
newly installed the other is brand new.
I’ve recently read the Gigaraid Function manual but still not sure how
to do this properly.
Can anyone direct me to a step by step guide or something similar.
Thanks in advance
Jim
http://www.HardwareForumz.com/ This article was posted by author's request
Articles individually checked for conformance to usenet standards
Topic URL: http://www.HardwareForumz.com/Gigabyte-GA-7N400-Pro-Gigaraid-Function-ftopict40858.html
Visit Topic URL to contact author (reg. req'd). Report abuse: http://www.HardwareForumz.com/eform.php?p=194631
jimbo121 <UseLinkToEmail@HardwareForumz.com> waxed eloquent in
news:419d0a5a$1_1@alt.athenanews.com:
> Hello
> Thanks in advance
> Jim
Are you planning to do RAID-1, or RAID-0? If RAID-0, you're going to
be re-installing XP. If RAID-1, you may be able to avoid re-loading the
OS.
Reply to for SPAM only
All others use:
m0ng0lh0rde @ ukonline . co . uk
Remove spaces to send
Thank you
> > Hello
> to set up
> One has xp
> not sure how
> similar.
> > Thanks in advance
> > Jim
> going to
> re-loading the
> OS.
> All others use:
> Thank you
Thanks for replying.
I was intending on setting up raid O, as I understand it it improves
performance. However I’d rather not have to reinstall xp so i’d be
happy to go for raid 1. If i understad this correctly it offers me
some protection in the event of a HDD failure.
Do you know how I set this up. The Gigaraid Function Manual is so
confusing to me, as I dont Know very much about computers.
Any help would be brill.
Visit Topic URL to contact author (reg. req'd). Report abuse: http://www.HardwareForumz.com/eform.php?p=199149
news:41a375c6$1_1@alt.athenanews.com:
> > > Hello
> > to set up
> > One has xp
> > not sure how
> > similar.
> > > Thanks in advance
> > > Jim
> > going to
> > re-loading the
> > OS.
You understanding of the two types of RAID are correct. However,
interestingly enough, I have seen some articles on the web that indicate
for the average home user, there is little, if any, benefit from RAID-0
that could not be equaled by a single drive of equal capacity to the two
drives in the RAID array.
This isn't to say that RAID-0 is not faster, but it depends entirely on
what you are doing. RAID-1 does provide data redundancy, in that
everything on one drive is mirrored on the second. If one drive fails,
most systems will use the second drive. Once you replace the failed drive,
you rebuild the array, and keep chugging along. RAID-0, if you lose a
drive, you lose ALL the data on the array.
Setting up a RAID array isn't too hard.
Make sure you have the RAID controller enabled in the BIOS.
Connect the two drives you are going to be using to the two RAID ports
After the system BIOS goes by, you'll have the option to enter the RAID
BIOS
Once in the RAID BIOS, use option 1 [Auto Configure] and choose Mirror
After the Array is setup, you will then need to rebuild the array. This
will duplicate one drive to the other, and make it ready to go.
A few words of warning though.
1. Make sure when you choose to rebuild the array, you pick the correct
drive to mirror *FROM* or you will overwrite your WinXP with a blank drive.
Which would be bad.
2. It's distinctly possible that after doing this, you may get a BSOD from
Windows, indicating an "invalid boot device." XP does not have a built-in
driver for the ITE controller, *AND* the boot.ini file will not be pointing
to the correct place. Part of the reason for this is that the RAID
controller is seen as a SCSI device. So even doing a RAID-1 array, you may
(likely will I think) have to re-install XP anyway.
All others use:
Thank you
> > "Jason Ash" wrote:
>  > > jimbo121 <UseLinkToEmail@HardwareForumz.com>
> waxed eloquent in
>  > > news:419d0a5a$1_1@alt.athenanews.com:
>   > > > Hello
>   > > > I have a Gigabyte GA-7N400 Pro 2 motherboard
> and would like
>  > > to set up
>   > > > the Gigaraid function using 2 Maxtor 40 gig
> ata/133 drives.
>  > > One has xp
>   > > > newly installed the other is brand new.
>   > > > I’ve recently read the Gigaraid Function
> manual but still
>  > > not sure how
>   > > > to do this properly.
>   > > > Can anyone direct me to a step by step guide
> or something
>  > > similar.
>   > > > Thanks in advance
>   > > > Jim
>  > > Are you planning to do RAID-1, or RAID-0? If
> RAID-0, you're
>  > > going to
>  > > be re-installing XP. If RAID-1, you may be able to
> avoid
>  > > re-loading the
>  > > OS.
> improves
> i’d be
> offers me
> is so
> However,
> that indicate
> from RAID-0
> to the two
> entirely on
> that
> drive fails,
> failed drive,
> you lose a
> RAID ports
> the RAID
> BIOS
> choose Mirror
> array. This
> go.
> the correct
> blank drive.
> Which would be bad.
> get a BSOD from
> have a built-in
> not be pointing
> RAID
> array, you may
> All others use:
> Thank you
I managed to setup a mirrored array following your instructions.
Thanks very much for the help and advice.
Visit Topic URL to contact author (reg. req'd). Report abuse: http://www.HardwareForumz.com/eform.php?p=201254
news:41aa2df1$1_1@alt.athenanews.com:
> > waxed eloquent in
[Snipped a bunch of the thread, and some bad quoting]
Not a problem.
All others use:
Thank you
