GeForce GTX 750 Ti Review: Maxwell Adds Performance Using Less Power
Page 5 - Seeking answers? Join the Tom's Hardware community: where nearly two million members share solutions and discuss the latest tech.
If it were running stock clocks, it would be marginal to OK. However, if you look at the CPU-Z image, you'll see it's at 995MHz. That's not stock clocks.
I mean mostly in terms of the size it takes up on the card itself; adaptors to DVI are easy to get ahold of if you need them, and it wouldn't cost much for a card manufacturer to bundle at least one. There's also mini DVI as an option; I just think that if you're going to make a card nice and small then it should be designed for more space constrained environments rather than simply the budget segment, and blower style coolers are much better for such systems.
Yes i reedited my response after taking a careful look at the CPU degrading settings lol. Maybe i didn't take much notice but why undervolt and underclock the CPU? Why not use advanced cpu profile to manage clocks which can be switched later to more where needed thats what i do on my 1090T. I switch to 800-1600Mhz 67W when im on mild usage.
No they actually announced they are no longer going to make the FX series and are abandoning their most ardent supporters to become a mediocre tablet cpu company..
Well done NVIDIA. At 60W, I'd be tempted to have one myself. Making a card go fast is one thing, but doing so at such frugal levels is far more meaningful especially if electricity isn't cheap.
There is low power performance and there is headroom. What makes this chip so exciting is how cool running it is at 900mhz. Overclocked to 1050mhz it has 20 Cecilius of thermal headroom to use. It the same idea Intel used when it came out with the Core 2 technology. Core 2 was Intels first chip designed from the bottom up. They made the mobile chip first and up scaled to the desktop and extreme versions. the first core 2's were 60 watts and air cooling cooling could take them from 2 ghz to 4 or 4.5 ghz without and trouble. This chip could prob run at 2 ghz without the locked multiplier. The 20nm version could make it to 4 I bet.
That might be a little optomistic. By memory, there's something like a cube law between frequency and power required - double the frequency, eight times the power.
We might not see it until the flagship, or mobile versions... :/
Dry
Oh nono like i said up ther, they are not dropping everything. The fx lineup maybe coming to EOL, but as i said they are planning new arch to FM2+ and Future probable FM3 etc, thats what they meant by unifying the architecture. No longer APU one side, Processor alone other side, performance this no L3 this etc etc. They will just make 1 type of processor just like intel does.
Actually, it was closer to a 7850 in terms of performance.
Excuse me pal but who pointed fingers first? and talked about AMD fanboy etc, im not an AMD fanboy, i just stated a fact and it turned into fanboy stuff. I have owned 2 Nvidia cards and 2 ATI cards. ATI always beat Nvidia in PPR.
60watt and deliver 1080p? My jaw just dropped :OAt $150 level of performance somewhat persist and that crazy low power, it would shine gloriously on the entry level gaming builds, really.Unless AMD reacts something about this soon, this card would become my main option for sub $150.*time to upgrade my 7750 I bought at launch at about the same price as this
Agreed. It does a lot more with less, and that is never a bad thing.
...which leads to this.
I've got a very small build that just doesn't quite have as much "oomph" to it as I'd like for some of my games; it has a low-profile HD7750 in it. A low-profile version of the GTX750Ti is a no-brainer for that build, and will make it viable for everything I run at "good" (not just "acceptable") settings.
Can't wait for a low profile version. Finally, nVidia seems to care about this space, which should push AMD to update and improve its 7750.
Unless there's an actual statement agreeing with this, it's not correct; roadmaps that lack information don't necessarily mean there aren't plans to bring FX back, and in any case, roadmaps are always subject to change.
My HD5770 died (rip) and Im looking for a new card with decent performance for under $200. It gave me GTX260 performance with less power consumption which is a big thing for me. This card is nice and I would like to have it. If I'm correct the GTX750ti (SC) would be a fitting upgrade from radeon.
I'm actually amazed you somehow still think you're right. I thought you were done?
So proving AMD isn't "always" the better price/performance option is "raging over the obvious", but simply stating that AMD is "always" the better price/performance option serves as "fact"? I mean what are you trying to say? That you always ignore evidence that doesn't conform to your agenda? Or maybe you're saying people should simply shut up and accept your assumption that AMD's always the better price/performance option, or that AMD always has inferior drivers, or that AMD fanboy's are stubborn trolls that advance their agenda through misinformation? I'm honestly curious because I don't know what you're trying to say, and I'm not convinced you know either.
It's true I called you a fanboy, but it was only after you gave an unrelated fanboyish response, which we're still talking about now instead of the original topic you posted, and that I intended to discuss. So I would argue that you started it. I'm not sure what you were expecting, maybe you weren't expecting me to respond at all?
And sorry dude, but I don't think saying that you've owned Nvidia hardware makes you any less of a fanboy than owning a GTX480 makes me a performance only enthusiast. But I am noticing a distinct trend towards deflection and pigeonholing in your comments, so I guess that would make sense.
yikes... anyway, i don't think anyone is complaining about the 750ti. it's a 15% improvement over the 650ti, and does it with half the power. Frankly any gpu producing performance numbers over a hd 7770 and under a hd7790 and managing on 2/3 the power of both is doing something REALLY right.
Its a nice card, now if only nvidia would sell it for $120... at that price it would be a flippin' awesome card. That said i fear this little beast will become the core of many CUDA mining rigs and soon will be selling for way more then $200
Historically, every time NVidia or AMD comes out with a new chip that performs roughly on par with the one from the last series, they've screwed consumers over with pricing for two generations of boards. All those folks who were waiting on Maxwell to grab a new card might want to keep waiting.
