[SOLVED] Ghost ethernet connection??
AsGSnak
11
Hello.
Everytime I connect to a Wireless network, I always get a "ghost" ethernet connection appearing, even though I have no ethernet cable pluged in. It even happens if I disable my ethernet adapter and leave only the wireless one on. It only goes away when I disconnect from any Wireless connection.
I've tried deleting all my wireless connections from memory and I deleted all the network profiles from Regedit (wireless and ethernet) but it shows up as soon as I connect to a Wireless connection. What is happening?
ASUS A53S laptop MB model: K53SV
CPU: Intel Core i7-2630QM @ 2.00GHz
RAM: 4GB
OS: Windows 7 Professional 64 bits
Thanks in advance
Diogo
Your main router (providing DHCP IP addresses) is 192.168.8.1.
That router is the only device that should have DHCP enabled. The second router (AP) should have DHCP disabled.
The ASUS-PC is using wireless connectivity and was (at the time that "ipconfig /all" was run) being provided the DHCP IP address of 192.168.8.111 - that IP can change.
Noted though that your original post identified a laptop (ASUS A53S laptop MB model: K53SV ) versus a PC. Is the laptop's name actually ASUS-PC?
Verify that, on the laptop, only the wireless network adapter is enabled as it is being connected wireless. (Network connectivity should be either wired or wireless. Not both wireless and wired at the same time.
Make and model main router...
Hello.
Thanks in advance
Diogo
Your computer is trying to show you everything that is available thru the air. If not it may be someone that is or did try to connect to you and the bug is still trying to find you. When I see too many of these oddities it is time for me to format them all away.
Update your post to include full system hardware specs and OS information.
What network adapters do you have installed?
Run "ipconfig /all" (without quotes) via the Command Prompt and post the results.
Also run "arp /a" and post the results.
Are you in an environment with many surrounding wireless networks and wired/wireless networked devices?
Reactions: AsGSnak
RAM: 4GB
Wireless: Qualcomm Atheros AR9002WB-1NG Wireless Network Adapter
Ethernet: Realtek PCIe GBE Family Controller
Bluetooth Device (personal area network)
Bluetooth Device (TDI protocol RFCOMM)
Configuração IP do Windows
Nome do Anfitrião. . . . . . . . .: ASUS-PC
Sufixo DNS principal. . . . . . . :
Tipo de nó. . . . . . . . . . . . : Híbrido
Rota IP activada. . . . . . . . . : Não
WINS Proxy activado . . . . . . . : Não
Adaptador ethernet Ligação de rede Bluetooth:
Estado do suporte . . . . . . . . : Suporte desligado
Sufixo DNS específico da ligação. :
Descrição . . . . . . . . . . . . : Dispositivo Bluetooth (Rede de área pess
al)
Endereço físico . . . . . . . . . : E0-B9-A5-9B-6C-0F
DHCP activado . . . . . . . . . . : Sim
Autoconfiguração activada . . . . : Sim
Placa de rede local sem fios Ligação de rede sem fios:
Descrição . . . . . . . . . . . . : Qualcomm Atheros AR9002WB-1NG Wireless N
twork Adapter
Endereço físico . . . . . . . . . : E0-B9-A5-85-D1-9F
Endereço IPv6 de local de ligação : fe80::25c0:e871:a945:1d05%10(Preferido)
Endereço IPv4 . . . . . . . . . . . . . . : 192.168.8.111(Preferido)
Máscara de sub-rede . . . . . . . : 255.255.255.0
Concessão obtida. . . . . . . . . : sexta-feira, 19 de março de 2021 12:18:4
Concessão obtida válida até . . . : sábado, 20 de março de 2021 12:18:41
Gateway predefinido . . . . . . . : fe80::8af8:72ff:fe24:f1%10
192.168.8.1
Servidor DHCP . . . . . . . . . . : 192.168.8.1
IAID DHCPv6 . . . . . . . . . . . : 249608613
DUID Cliente DHCPv6 . . . . . . . : 00-01-00-01-24-AB-0B-EF-E0-B9-A5-85-D1-9
Servidores DNS. . . . . . . . . . : fe80::8af8:72ff:fe24:f1%10
192.168.8.1
192.168.8.1
NetBIOS por Tcpip . . . . . . . . . . . . : Activado
Adaptador Tunnel isatap.{073DAC23-47F1-48BC-891B-F77D634D3EA1}:
Descrição . . . . . . . . . . . . : Placa Microsoft ISATAP
Endereço físico . . . . . . . . . : 00-00-00-00-00-00-00-E0
DHCP activado . . . . . . . . . . : Não
Adaptador Tunnel isatap.{D6438AB4-CADE-4644-BC96-29F4A5BDA328}:
Descrição . . . . . . . . . . . . : Placa Microsoft ISATAP #2
Interface: 192.168.8.111 --- 0xa
Endereço Internet Endereço físico Tipo
192.168.8.1 88-f8-72-24-00-f1 dinâmico
192.168.8.5 00-22-b0-fa-6e-f8 dinâmico
192.168.8.103 b2-4e-26-29-89-a7 dinâmico
192.168.8.200 1e-3b-f3-00-f1-64 dinâmico
192.168.8.255 ff-ff-ff-ff-ff-ff estático
224.0.0.22 01-00-5e-00-00-16 estático
224.0.0.251 01-00-5e-00-00-fb estático
224.0.0.252 01-00-5e-00-00-fc estático
239.255.255.250 01-00-5e-7f-ff-fa estático
255.255.255.255 ff-ff-ff-ff-ff-ff estático
I have only my home network (main router, 1 router as AP and 2 wireless extenders) all with different SSID, so 4 total networks. No networked devices and some wireless devices (mostly laptops and smartphones).
I must say this also happens in another household I live in, with another network. Actually, now that I look back, I think this started happening when I connected this laptop with an ethernet cable to a router, to access the router configuration page.
Make and model main router? Make and model AP router?
Are you using a LAN to LAN port Ethernet connection between the main router and AP?
Have you created any static IP addresses within your network? If so, what devices and what IP did you assign? Static IP addresses should be outside of the DHCP IP address range allowed to the main router. And the Static IP addressed for the applicable device via the device's MAC.
For your information verify that you know what each of the following devices is:
